#40956 04/11/26 02:46 AM
Have a duplex 3300s and having issues with one car. It will not move in inspection, Cartop or machine room.
As soon as it boots up it gives 3626, 3620, and one other communication fault. I can’t remember the last one. Tried the 101 reset, along with killing the power and disconnecting the battery for 24hrs. It still boots up and throws those faults right away. Along with status 70.
Any help would be greatly appreciated thanks
MX4 Offline
What drive?
Vaf023 id is 59415525
It’s in the overhead and I cannot get to it right now.
MX4 Offline
Check CAN H & CAN L at WDPNA
Check 24v from semna
You may have to access cartop so you can get to the drive and look at the light sequence on the drive (some diagnostic LEDs) while you’re up there check 24v at drive
It’s almost like there is no power on the communication side. Cause all the codes are com node dead on drive, main board, and car. Power supply has the green light on and I cave 24v on the jhs aux contacts. I’ll dig into deeper Monday. First fault it throws powering up is 3618 then the rest follow.
Thanks for the info and I’ll get back after Monday to see what else.
Also there is no wires in the plug for CanL on the wdpna board. I wish I had the prints, that would help a ton.
MX4 Offline
PM me your email
Sent. Thank you
Worth changing JHS aux contacts (or jumping them temporarily while onsite to test it), have had some weird issues due to intermittent bad connection from those before
PHP: 8.3.33 Page Time: 0.029s Queries: 32 (0.008s) Memory: 3.0337 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 18:26:34 UTC
