#4359 08/14/12 12:53 PM
Got problems with kone eco drive levelling
It's stopping 200mm short in down travel and comes
Up with fault 01 08
It's works fine in up travel
Simon #4361 08/14/12 04:55 PM
Where are you located, Simon?
Vic #4365 08/14/12 06:24 PM
Uk
Simon #4366 08/14/12 09:57 PM
0108 is a Motor/tacho fault. The car isn't doing what the control wants, or the tach wheel is dirty, sheave dirty, or you could blow out the tach brush rigging, if it has removable caps.
Check your loadweighing, menu 5,1
Displays the current load, as a percentage of capacity. It might think it weight in it that doesn't exist, so it's scaling back the motor torque, as it's pulling the counterweight up. If it assumes there is signifigant weight in the car, it may be expecting that, and so alters the S-curve accordingly. Just a guess.
Maybe one of our Kone experts will chime in.
BTW, great job at the Olympics for the UK! Great show, and excellent medal count results, especially for a pool of 65 million people. Punching above your weight!
Vic #4375 08/15/12 05:01 AM
elevator lifer
elevator lifer
good call vic I would give an a+ for that one
aquadag #4377 08/15/12 06:04 AM
Cheers Vic, will have a look today
aquadag #4383 08/15/12 05:03 PM
Heh heh, thanks, aquadag! It was a "SWAG". (Scientific Wild Ass Guess)
There are so many other possibilities, the mind boggles!
Simon,
I think the first thing is just to have a good look at it, and see what the drive is doing, the run command, the pattern, Safe Circuit and Door Locks, Start Permit, Drive Need, the brakes, etc. Just get a sense if it's try to stop there, (off floor level), or if it is trying to actually stop AT floor level, but isn't able to because of some anomaly. Along this journey, many things could be discovered unrelated to loadweighing. But it's a start.
Vic #4466 08/26/12 05:32 PM
Well, Simon?
We're anxiously awaiting the result of the load weighing check?
Don't leave us hanging on a hook!
laugh
PHP: 8.3.33 Page Time: 0.023s Queries: 30 (0.007s) Memory: 3.0319 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 17:42:35 UTC
