Topics7,432
Posts41,135
Members10,097
Posts: 11 |
Hi all, is it possible to access Kone cpu561 lce? I’ve recently obtained some units the older CPUs are fine though I can’t get 561 talking properly
Posts: 235 Likes: 4
TouchOfTheTism’
TouchOfTheTism’
Posts: 235 Likes: 4 |
I assume you are outside of the USA & Canada?
Posts: 281 Likes: 5
Posts: 281 Likes: 5 |
Did you replace a cpu40 with cpu561 ?
Posts: 11 |
No didn’t replace cpu, I’ve just got another cpu 40 job that’s older that I can connect to via putty serial emulator. Try the same setup on cpu561 and I’m not able to get in
Posts: 235 Likes: 4
TouchOfTheTism’
TouchOfTheTism’
What settings are you using?
Posts: 11 |
9600 null connection 8 data bits no parity 8n1
Posts: 235 Likes: 4
TouchOfTheTism’
TouchOfTheTism’
9600 transfer, 8 data, 1 stop, 0 parity.
Have you tried different 561 cpu?
Posts: 11 |
Not as of yet, is that your suggestion ?
Posts: 235 Likes: 4
TouchOfTheTism’
TouchOfTheTism’
Yes I would try a different one, I originally thought you were across the pond bc you would need a different tool
1 member likes this:
Thegoat2 |
