October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#41116 05/22/26 09:50 AM
Hi all, is it possible to access Kone cpu561 lce? I’ve recently obtained some units the older CPUs are fine though I can’t get 561 talking properly
Thegoat2 #41117 05/22/26 12:53 PM
MX4 Offline
I assume you are outside of the USA & Canada?
Thegoat2 #41120 05/22/26 10:17 PM
Did you replace a cpu40 with cpu561 ?
Thegoat2 #41121 05/23/26 04:05 AM
No didn’t replace cpu, I’ve just got another cpu 40 job that’s older that I can connect to via putty serial emulator. Try the same setup on cpu561 and I’m not able to get in
Thegoat2 #41122 05/23/26 06:43 PM
MX4 Offline
What settings are you using?
MX4 #41123 05/23/26 09:51 PM
9600 null connection 8 data bits no parity 8n1
Thegoat2 #41124 05/24/26 12:30 AM
MX4 Offline
9600 transfer, 8 data, 1 stop, 0 parity.
Have you tried different 561 cpu?
MX4 #41125 05/24/26 03:44 AM
Not as of yet, is that your suggestion ?
Thegoat2 #41126 05/24/26 12:39 PM
MX4 Offline
Yes I would try a different one, I originally thought you were across the pond bc you would need a different tool
1 member likes this: Thegoat2
PHP: 8.3.35 Page Time: 0.230s Queries: 33 (0.093s) Memory: 3.0338 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-10-11 02:52:00 UTC
