10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
#41272 07/07/26 01:25 PM
Hi
I have an issue with Otis gen2.
Lift stays on INS. When on the status menu, it flashes carlights.
I have these 3 faults all register at same time.
Rsl sync
DOL alw on
TCI/ero on
I suspect it being a RS board dragging can bus down.
Is there away of testing the RS boards with service tool.
Pjf79 #41274 07/08/26 10:10 PM
The RSL shouldn’t have anything to do with the inspection circuits. You can test RS via M-1-2-1.
Pjf79 #41276 07/09/26 04:12 AM
ERO is a European term, closest thing we have to
that equipment in NA is Spec 60s which was almost 40 years ago now. I've worked on a handful of marine stuff with LCB2. i doubt your problem of staying on inspection is serial link related, none of the inspection stuff will
be ran off an RS board.
Pjf79 #41297 07/15/26 07:34 PM
nvatorm
nvatorm
Is the lift stuck on top of car inspection? Have you tried running it from car top (with & without door lock bypass) I cant remember if the DOL is active high or low on those, is the car door closed or open?
I would check the top of car inspect wiring on the switch and the DOL sensor if it is in the wrong state.
Have you done the following resets? (M151, M152, M152, M2231)
Pjf79 #41300 07/15/26 08:26 PM
There is no rsl line from tcbc board with shaft and car lines unplugged, none of the lines decking to earth. I’m changing TCBC board tomorrow. So fingers crossed.
Pjf79 #41600 10/08/26 10:24 PM
Hello. In my Experience, Inspection mode (if in Control panel, and car top swiches 'Insp/Norm' Set as Norm, but active inspection mode (on SPBC or TCBC, OR GECB pcb Led 'Ins' Active') perhaps can be if RS-14 on J-BOX (from car top) adr 19 was a badly (bad pcb RS-14 adr 19). Adr 19 used for inspection on car top. I have some elevators Otis, and that i caught on OTIS Gen2 controller MCS 220 RX2 with SPBC III & GECB, perhaps similar trouble on MCS 220 C, MCS 220, MCS 220 CX and etc. Check the Schemes, if that same as i say, check it. You can do the 'self-test' (with Service tool if you have it), but that not best way. Rsl line after test may show you wrong device. Best way, (if you doesn't have svt), that: swap the RS14 with other (19 adr, and 18). What it give you? If Rs for 19 adr (inspection) bad, and you swap it on 18 adr, you see that a Door inv can off or something be wrong in work door. Adr 18 used for Doors (Door inv, DCSS, Photocell, and ST1,ST2,ST3 Commands (inputs)). Best regards.
PHP: 8.3.37 Page Time: 0.035s Queries: 26 (0.008s) Memory: 3.0222 MB (Peak: 3.5941 MB) Data Comp: Off Server Time: 2026-11-25 01:59:39 UTC
