This unit keeps blowing the controller s15 3 amp fuse. When we disconect all of the terminal plugs from the CIO car station board- the fuse holds. Where is the best place to get this board? Do i need any programming tool or is it just a swap? Thanks. Sr.
Had a problem with a fuse blowing on the CRIPHNA board. Would not blow when powering up on inspection,flip to auto and fuse would blow. Found a shorted thermal in the motor. Temp. Disconnected thermal, replaced motor eventually.
Scott You could try Mike Tuttle @ ECI America or Sean @ World Electronics. Adams is owned by Schindler but I have found their prices to be much higher.
