This unit keeps blowing the controller s15 3 amp fuse. When we disconect all of the terminal plugs from the CIO car station board- the fuse holds. Where is the best place to get this board? Do i need any programming tool or is it just a swap? Thanks. Sr.
Adams,maybe.or SEES.
Wrench
Wrench
Yep common problem. No tool needed straight swap just check the software chip and the right version board.
Just can't leave it alone!
Had a problem with a fuse blowing on the CRIPHNA board. Would not blow when powering up on inspection,flip to auto and fuse would blow. Found a shorted thermal in the motor. Temp. Disconnected thermal, replaced motor eventually.
Scott
You could try Mike Tuttle @ ECI America or Sean @ World Electronics. Adams is owned by Schindler but I have found their prices to be much higher.
BSP
BSP
IT COULD BE YOUR CAR DIRECTIONAL LATTERN BLOWING THE FUSE.PLUG IN ONE AT A TIME TILL IT BLOWS.THEN TRACE
MBKE
PHP: 8.3.36 Page Time: 0.026s Queries: 26 (0.007s) Memory: 3.0208 MB (Peak: 3.5934 MB) Data Comp: Off Server Time: 2026-11-05 20:08:57 UTC
