#41410 08/13/26 06:41 PM
Hi, everyone.
I'm currently working on a Kone Monospace (1999) with an interesting configuration: LCECPU561 + V3F16ES.
The menu items "d" and "2" no longer exist on this LCECPU, and "6" doesn't work.
Is there a way to read and change the parameters and read the error log via the Sub-D connector?
That sounds like an interesting combination, normally v3f16es parameters are in menu 2,
if it could be in menu 6 you need a newer drive, what kind of menu do you have and what kind of lce software are you running?
I think with that setup you to change, you need to dou it on hyperterminal
I had this issue up in Scotland about a year ago, luckily it was a duplex so I copied the NVram from the other drive on my pc, did the setup drive and Bingo 👌
Dave
PHP: 8.3.33 Page Time: 0.020s Queries: 20 (0.006s) Memory: 3.0037 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 05:23:05 UTC
