10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
Hi Guys,
Does anyone have a print for a Garaventa Genesis Vertical Lift Model HY-US-EN-60? Having trouble with one and looking for a print to troubleshoot.
Thanks,
Tom
What is the print number?
For a Genesis HY-US-EN-60, I'd start by checking the serial number and any drawing or revision number on the controller or in the original paperwork.
Garaventa has used different configurations on these lifts, so a generic Genesis wiring diagram might not match the exact unit you're working on. The original installer or Garaventa's technical support may be able to track down the correct prints using the serial number.
What's the lift actually doing? Is it completely dead, running in one direction only, or showing some kind of door or gate fault? That might help narrow down which part of the circuit you need to look at.
I'd avoid bypassing any safety interlocks while troubleshooting it.
If you're still having trouble figuring it out, you could also try reaching out to All Star Lifts. They're a mobility equipment company based in Pennsylvania that works with stairlifts and vertical platform lifts. They might be able to offer some guidance or point you in the right direction, although I'm not sure whether they have the specific drawings for this model.
The serial number has nothing to do with the print number. The print number should have been inside the controller. Sometimes on the front cover of the controller, the rear side of the coover, or even on a paper stick-on on the wiring duct cover. If you want schmatics that match what you have, you need the print number. If you get me the print number, I probably have the proper schematics. I was a dealer for almost 20 years
pics of the inside of the controller, both sides of the controller cover and a description of the equipment supplied might be helpful. Year of manufacture might help. Specific problems? Where are you located?
PHP: 8.3.37 Page Time: 0.031s Queries: 24 (0.010s) Memory: 3.0189 MB (Peak: 3.5940 MB) Data Comp: Off Server Time: 2026-11-25 01:32:43 UTC
