10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
I have a Dover composite that is intermittently not reopening its doors off of a up or down hall call from where the car is sitting. Any tips would be appreciated.
If you are referring to when the car is sitting at the floor it’s not opening for the hall calls, it still uses the UC and DC coils picking to start the CS SE circuits, just through a different path.
Thank you Sammy1
I have not been able to fix this problem yet. I have noticed that when I am at an upper floor and place a hall call, the car will arrive but not open the doors.
If you can catch it messing up, as it comes into the floor the CS relay needs to pick up , which picks SE if 2LR is picked. SE gets OD, The CS relay should stay picked until the DS relay picks off the DT timer.
Good luck
If you hold in the OD relay in the controller will the doors open? You might have a blown fuse?
PHP: 8.3.37 Page Time: 0.030s Queries: 28 (0.009s) Memory: 3.0237 MB (Peak: 3.5946 MB) Data Comp: Off Server Time: 2026-11-25 02:01:07 UTC
