10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
#41691 11/17/26 02:02 PM
Elevator Apprentice
Elevator Apprentice
Good Morning, we have a Otis 6840. Timer tube lights up after determined time but it never shuts the generator off. Any help or light in this? We replaced the capacitor in the back of it with the same type and still not working. [Linked Image from i.imgur.com][Linked Image from i.imgur.com]Attached some pictures
Does the bi-metal contact strip open (or close) when the MGT timer tube lights up? It appears the gap is adjustable at the top.
1 member likes this: NewMech
Elevator Apprentice
Elevator Apprentice
The bi-metal strip never moves, even when the tube lights up. Its always touch the front part on top, I’m starting to think if it could be the coil that pulls it back, that went bad?
Elevator Apprentice
Elevator Apprentice
If you manually push the contact closed when the tube lights (and there’s no motion!), does the generator shut down? Could be the coil. Be sure the contact itself moves freely from NC to NO.
That looks to be an adjustable pot for time to the right of the tube. Note the time when the car parks until the tube lights. Mark it and try 1/4 turns (or more if no change) in or out and see if there’s any change.
Tube failure is common on this timer.
If you can find another tube, give that a shot.
Otis sells a replacement timer assembly with a contactor and Artisan timer.
Elevator Apprentice
Elevator Apprentice
Yes, if I push the contact closed the generator shuts down, I’ll try those suggestions and I’ll get back to you, thank you so much!
Elevator Apprentice
Elevator Apprentice
Oh they do sell a replacement? I’m having a hard time finding the tube, by any chance would you happen to have a part number or something that points me to that replacement timer assembly? I would really appreciate it
If the generator shuts down by pushing the contact closed, I’d check the coil before moving forward and double check that timer pot next to the tube to see if it’s culprit.
Typically I would agree, but………
If the coil is bad, a direct replacement is not available.
If the pot is bad, a direct replacement is not available. Yes, you could grab any pot and install it.
If the tube is bad, a direct replacement hasn’t been available for years.
I’ve replaced at least a dozen of these, the tube has been the culprit every time. I’ve got a pile of tubes that I’ve saved from tube to button conversions in the event I don’t have a replacement timer on hand.
AAA21050A1
PHP: 8.3.37 Page Time: 0.037s Queries: 38 (0.011s) Memory: 3.0531 MB (Peak: 3.5943 MB) Data Comp: Off Server Time: 2026-11-25 01:34:52 UTC
