#4556 09/07/12 12:10 PM
Can anyone help on a miprom 21 problem. Keep getting 41 fault. Car runs but only makes floor to floor runs and throws 41 faults. Already changed encoder and speed boards.
Garmin #4558 09/07/12 12:54 PM
Commutation???
Broke_Sheave #4561 09/07/12 09:38 PM
41-saw the intermediate speed (67%) out of tolerance. May be a problem with the tach on the motor or an issue with the ETS board (not uncommon) Make sure your TM switch is correct and or your hoistway slow downs are correct.
Broke_Sheave #4565 09/08/12 01:59 AM
A/C drive. No generator
E311 #4566 09/08/12 02:01 AM
Replaced ETS and NTS boards. Ran set up and they are in tolerance.
Garmin #4567 09/08/12 03:09 AM
Still doing it?
Allen Bradley 1336 digital drive or Baldor 914 analog? (Both are the only AC's I know that are installed on this equipment.
If 1336 No NTS board. Done internally on the motion adapter board.
Garmin #4568 09/08/12 03:11 AM
You may want to check the ets switches in the shaft. Make sure RL2 on the ets board is operating correctly.
jkh #4570 09/08/12 04:18 AM
Is this problem happening consistently or intermittently? This must be an analog AC if you have changed the speed boards. If you have a scope meter you can check your signal coming from the encoder to make sure it's clean back to the drive boards.
Just went through this with a car that had a bad governor shaft causing intermittent encoder faults. Also, check the encoder power supply to make sure it's clean. Good Luck!!
Administrator #4574 09/08/12 11:50 AM
Its a Baldor 18H drive. RL2 is working properly. It happens on every run.
Garmin #4595 09/10/12 08:05 PM
Garmin how did you make out with this one?
Garmin #4598 09/11/12 02:50 PM
Probably a Baldor 914 originally. Obsolete, so drive was changed to 18H
Have you checked your motion averages? (And your dictation voltage?)
PHP: 8.3.36 Page Time: 0.038s Queries: 36 (0.009s) Memory: 3.0488 MB (Peak: 3.5928 MB) Data Comp: Off Server Time: 2026-11-05 17:03:36 UTC
