#4596 09/11/12 01:32 AM
Elevator will not run on any inspection operation.Inputs seem to be in order.I do not pick 201.3 and 201.4 because K2 relay does not energize.Runs on normal operation.Fault code 1 07 code.Have no info on K2 I think drive controls it.
kmic #4597 09/11/12 12:10 PM
Kmic,
I'm not sure but I think K makes when your doors are closed. Try running it on inspection from the car top. See if the door close limit is making? Try spinning the operator by hand in the close dirrection and see if it will run.
jkh #4601 09/11/12 07:52 PM
Doors look o.k..Replaced MRCB .K Relays mount there.Looks like everything is ready to go but it does not get a drive enable. when on inspection.
Runs on normal. Still searching
Ken M.
kmic #4852 10/11/12 05:59 PM
Updated Info
The drive receives a signal from the CPU which puts it on inspection drive.The CPU board ended up to be the problem.However the elevator know thinks its top floor is 24.It is a 5 stop.Parameters set to where they were prior to CPU board swap.I have limited info any is appreciated.
Ken M.
kmic #4853 10/11/12 09:12 PM
Have you tried this?? Post in thread by "Elevated"
http://www.vatortrader.com/forums/ubbthr...h=true#Post2125
kmic #4855 10/11/12 09:32 PM
Check access parameter. Must be set to top floor. Don't forget to save
PHP: 8.3.33 Page Time: 0.022s Queries: 26 (0.006s) Memory: 3.0193 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 09:23:28 UTC
