0 members (), 92 guests, and 3 robots.
Page 2 of 2 1 2
uppo72 #5848 02/13/13 03:44 PM
Unsure of your question Uppo?
A and B base refer to dispatching schemes. They are basicall identical, except A base was used mostly on touch button systems, and had multiple diagnostic cards you could plug into the card rack, and B Base was used with regular push buttons, and had one diagnostic board.
Both were based on VIP 260 logic, but transferred from relay form to DTL logic. (DTL = Diode Transistor Logic)
And to confuse things more, there was a CB base. Basically a B base dispatcher, but additonal boards that read flags in the hatch for Selector functions. Basically the 1st Otis that I'm aware of that did not have a mechanical selector.
uppo72 #5849 02/13/13 04:32 PM
O
O Offline
Also check for bent connectors on IBM relay bases as well. I have had those whip my butt on occasion. Peace.
Thanks broke i think you answered my question. I've worked on the touchbutton control(nightmares they are) feeding multiple cards on the lift no1 selector. I'm pretty sure this was the only high rise type here, with normal button style button types used with a geared machine and selector version for small applications. The next generation of otis lifts were the 401's and no cb base types. I've just read over the time posters stating a or b base and not really sure what they were referring to. Thanks mate.
uppo72 #5854 02/14/13 02:20 AM
Ah....Touch Buttons and Balanced Bridge detectors...The good old days.. grin
One of my first few days on the job, 35 years ago, my boss tells me..
"That tenite cover is loose over the door detector. Reach in behind it and tighten it up"..
Let's just say that 1000 cycle wouldn't kill you but it would make you hurt yourself trying to get away from you.. grin
Of course he thought it was hilarious. Different times for sure.. cool
ha i know what you mean. Touch buttons, saturable reactors on the pdo, old lambda with the high frequency were all stuff we, as newish mechanics freshly bought out by Otis all had to learn let alone fricken selectors that our company had p****d off 20 years earlier!
And those old pranksters soon realised not to piss us off as we fight back. smile
uppo72 #5958 02/21/13 06:06 AM
Sounds like LSP isn't picking and locking out leveling. Look there.
Stay safe.
marbles #5960 02/21/13 06:37 AM
Stay safe.
marbles #8865 11/03/13 02:03 PM
mjm Offline
One year later, I hope you found your problem, he-he. But I think as stated, UA and DA are respectively held in by SU and SD contacts I think. So, if SU or SD are dropping out for some reason, that would cause UA or DA to drop out hence allowing CS to come in and the car then relevels. So, check all contacts in the SU and SD circuits. Wish I had some prints. peace-out.
mjm #8878 11/05/13 01:47 AM
Problem with the Yellow Jacket relays is that the solder connections on the back of the relay can touch the contacts in the wire contact relay base. This can short circuits together not meant to be. I personally have been involved in trouble shooting three such occurances, twice while at Dover and once after leaving. All were documented, the first two bothto Dover and to World and the third to Works and Otis. No once seemed concerned. Best replacement is a new relay from Vertex and they aren't expensive.
uppo72 #8880 11/05/13 02:27 AM
Len Offline
.....the Vip260 is also gearless umv control system..had many of those cars in one building...the Test card in the operational controller slot YK..was a worth its weight in gold..
Len #8881 11/05/13 03:56 AM
mjm Offline
And another thing, I'm sorry to read that you young guys haven't learned what us old farts found out a long time ago. Those yellow jacket relays are crap. Just because they have an "led" on the front, everyone thinks they must be great. Well, they're not. Put in the relay that the base was made for guys. And like I said, you have to maintain SU and SD once you pick MO, or you're going to stop and relevel.
mjm #8882 11/05/13 05:07 AM
Len #8884 11/05/13 11:24 AM
Yeah most of the vip 260's I worked on was gearless at around 30 floors.
aquadag #29343 05/30/20 04:13 AM
Aqua, could you please email me the composite adjusters manual? [email protected]
Thanks so much,
Montana
Montana #38998 02/14/25 04:21 AM
I would like a copy also
marbles #39005 02/14/25 04:42 PM
Could you send me a copy as well? Thanks
aquadag #41252 06/30/26 05:40 AM
Still have manual by chance ?? [email protected]
Page 2 of 2 1 2
PHP: 8.3.36 Page Time: 0.045s Queries: 51 (0.013s) Memory: 3.1078 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 05:29:50 UTC
