#256 02/13/10 07:15 PM
V Offline
I have a Dover DMC-1A that we suspect has corrupted software. This is using the 6300BP4 board that only has 4 (27C256B) e-square chips on the board. Is this board fully programmable with the DMC tool or do you need proprietary software from Thyssen to communicate with the board? Any help would be greatly appreciated.
vatordude #258 02/13/10 07:17 PM
Service Manager
Service Manager
i use the world freedom tool and it works rather well
vatordude #263 02/14/10 11:24 AM
why do you suspect corrupted software...
what is it doing, not doing ?
Elevatorman_1 #264 02/14/10 04:19 PM
V Offline
The board got wet, so we replaced the board but it's still not responding to the tool or outputting from the board.
vatordude #265 02/14/10 06:53 PM
troubleshooter1
troubleshooter1
did you check the 5 and 12 volt power supply to the clc board? It might be one of the other boards, door or selector, if the communication chips were damaged on them then the clc wont communicate to the tool it will say clc absent. to check this either remove the communication cable from the door and selector and then see if the clc will communicate to the tool, if it does then plug on board in at a time to see which one kills the line. make sure the 12 volt power supply is set to around 10.75 volts, and the 5 volt is set at 5. also make sure that the 24 volt power supply from the controller is making it to the cop, If I can remember right I think the 24 volt supply passes through the toggle switch near the 5 and 12 volt power supply which is in the cop beneath the clc board.
PHP: 8.3.36 Page Time: 0.023s Queries: 24 (0.006s) Memory: 3.0161 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 03:34:36 UTC
