Posts40,945
Anyone know the Elevator energy saving unit?
20-45% saving?
Find it here:
http://www.elevatorenergysaving.com/item-id-1107.html
Are you looking into installing this? Or are you advertising it?
Look at the username then look at the web address...its obvious its just advertising!!!!
Appears to be nothing more than an aftermarket RE-Gen drive. If you read the PDF you'll see that it mentions all these companies that use this technology. Yep they all do. Just not THIS drive.
The logo has an maple leaf (Canada) and IPC. I researched IPC and they have several aftermarket regen drives. This is the same company that makes a lot of aftermarket products. Like Generator Field regulator to replace open loop control. 6970 close loop operator.
Last I heard Mike Salich was still on their engineering team, and he is one smart cookied.
All these aftermarket products are out there, but wedding them to the current system is the trick. Support from the manufacturer is critical when installing these components.
elevator lifer
elevator lifer
admin where ae you. Ugh whats with all the spam lately.
PHP: 8.3.33 Page Time: 0.056s Queries: 24 (0.015s) Memory: 3.0159 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 19:14:37 UTC
