0 members (), 73 guests, and 2 robots.
It's been quite awhile ago, but saw a post about someone sabotaging the Dover DMC's by cutting a resistor by the COP battery. If the resistor was clipped, the battery backup would not function. Does anyone remember the resistor number? I think, that I may have had some hanky panky played on me. Looked carefully today and didn't see an obvious resistor clipped. If my feeble memory is still working a bit, I recall it being resistor 54, 55, or one in the 50's......PLEASE HELP....can't keep reprogramming this thing everytimemthe power blips......Thanks
troubleshooter1
troubleshooter1
not a resistor, it is the d4 diode, just to the upper left of the battery. hook your meter to the ground connection on the clc board. you should have 3 volts on the anode of d4, this will let you know that the battery and the holder it sits in is ok. if you do not have 3 volts, which is the battery voltage, do not turn off the unit. the cathode side of the d4 diode is the 5 volt supply from the power supply.
Thanks Scott, your memory is a lot better than mine. Will check it tomorrow
PHP: 8.3.36 Page Time: 0.024s Queries: 20 (0.008s) Memory: 3.0047 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 09:30:09 UTC
