0 members (), 37 guests, and 0 robots.
JackO, Elevator mike, Tyshawn641, WVGeek, KYmuseum
9,914 Registered Users
Topics7,300
Posts40,546
Members9,914
#30014 10/05/20 04:58 PM
K
K Offline
Tac 32
CPU FPGA V1R4
IOD FPGA VERSION:0
BOOT V0R5
PLDBAD LED red, no SAFCPU OR SAFE LEDS
FAULTS ON START UP 1926,1925
So far I have done a spc programming with no luck. Thanks for any suggestions in trouble shooting. I'm leaning toward bad output from SAFECPU internal.
I
I Offline
What’s J16 set to?
L Offline
Did you try a get command?
W Offline
Try GET command and then WRT & RST.
If not check J16 as Dirt suggested. Should be 18 if a Hydro.
Hey Kcmprize, what was the cause/solution to this? Having a similar issue. And could use a hand
L Offline
I had the same thing happening. It ended up being a defective toggle on the IOD for the car door bypass
PHP: 8.3.31 Page Time: 0.037s Queries: 27 (0.012s) Memory: 3.0133 MB (Peak: 3.5868 MB) Data Comp: Off Server Time: 2026-05-20 16:59:58 UTC
